Posted by: | ronin161 | |
Data created: | 4 December 2020 |
Hi, Since i install R23 i have a popin product licensing, but i really don't know how to active it. The license This Computer can't be push and i don't understand the ip / Hostname stuff. Need help please ;) | |
4 December 2020
#29324 | |
4 December 2020
#29325 | |
4 December 2020
#29326 | |
4 December 2020
#29328 | |
nothing, the popin disapear and come back with the same message | |
4 December 2020
#29329 | |
4 December 2020
#29330 | |
Nope just check and nothing like that.. i hhave a r23 license, everything work well, every plugin, but not ornatrix... T_T | |
5 December 2020
#29334 | |
Let's try this: Install the License Server directly from the download page. https://ephere.com/plugins/maxon/c4d/ornatrix/downloads.html See the links under "Install License Server Only" and download the one that correspond to your OS. Jeordanis Figuereo (Product Designer. EPHERE Inc.) | |
7 December 2020
#29352 | |
Thank you! it work! | |
9 December 2020
#29371 | |
Hi !
I have a huge problem. it work like 2hours, but a lot of crash (due to octane i think).. so i try to unistall ornatrix because why not.. lol and rre-install it, but since i do that i don't see ornatrix anymore in C4D.... i try evrythink.. (install last version install demo, etc... but nothing work..) i''m on cinema 4d R23... can you help me please | |
9 December 2020
#29372 | |
Btw a lot of crash with octane.. the compatibility is not ok :/ | |
10 December 2020
#29385 | |
Hello... today i try to install it on another computer to see if it can work but this time the license server say that i don't have enough license.. so i can't use it on different computer (even if on my master computer the plugin don't work at all)? i'm sorry but since i buy your plugin i think i use it only once because i always had a lot of problem.. can you help me please? | |
10 December 2020
#29388 | |
10 December 2020
#29389 | |
the r23.008 and i check i don't have any update for c4d. | |
11 December 2020
#29398 | |
14 December 2020
#29411 | |
Hi! Sorry but same, i still can't use it on my other computer, and i still can't see it on my main computer... you want me to create another ticket but the 1st one (can't use ornatrix) still my real problem. can we talk by email and find a solution? thank you.. i really need a solution, we own the plugin and need it for a project.
16 December 2020
#29419 | |
Hello! can you come back to us please..? it's really a problem for us, we bought it, we just want to use it... | |
17 December 2020
#29422 | |
Hi, This is what is happening. You have 1 license for Ornatrix Cinema 4D. This license is already assigned to RONIN161-JH. This is why it says: "you do not have enough licenses for this project" meaning that you do not have enough licenses remaning. So you will not be able to use Ornatrix in a second computer unless you release the license from RONIN161-JH first. The online licensing system that would allow you to use the license online and move it between computers like you expect is not implemented in C4D yet, only in Maya and Max. Now, you are getting this error in both computers, right? The license server gets stuck like this after a Windows update or when you change some hardware in your computer. It can also happen when you replace your modem. In this case you have to release your license and reinstall the license server. Instructions here.
17 December 2020
#29423 | |
HI! Ok i understand. when this feature will be availble? cause it's really important to be able to work on different computer (especially if the plugin don't work on my main computer...)
And no, i don't have this error on my main computer, because like i say on my first message, i don't see the plugin when i open c4D. I have a huge problem. it work like 2hours, but a lot of crash (due to octane i think).. so i try to unistall ornatrix because why not.. lol and rre-install it, but since i do that i don't see ornatrix anymore in C4D.... i try evrythink.. (install last version install demo, etc... but nothing work..) i''m on cinema 4d R23... can you help me please" | |
17 December 2020
#29424 | |
Hi, If you don’t see the plugin in C4D it could be because ythe C4D version that you are Using is not compatible with Ox. Here are the minimum requirements. For R23 we are testing on R23.110. If you are using thr archive installation method, use the installer instead. If you get another crash with Octane send me the crash log and the scene, we will investigate. However Octane is not fully compatible yet. Regardless of our efforts we have not received much help from them. You may want to post about the crash on their forums as well.
17 December 2020
#29425 | |
i have the r 23.008 and it work on my other computer (i have the license window when i start c4d) but not the main computer. the config is the same. maybe a cache or regedit stuff, i don't know.. even if i re-install the plugin, nothing happen. i'm sorry for this long thread, but i just want to use your plugin :) | |
17 December 2020
#29427 | |
17 December 2020
#29428 | |
17 December 2020
#29429 | |
thanks for the reply i will give a try tomorrow! (And yes thank you! it work fine on my other computer, i just realese the license and the plugin work fine here) | |
18 December 2020
#29433 | |
Just try to point to the right folder and it work! thank you so much for your time. about octane i will send some message on their forum too :p Have a nice day ;) |
