UV Tags not showing when using Mesh From Strands for multiple UV uses
Posted by:willilix
Data created:20 September 2021
Hi there,
My company just rented out Ornatrix so i could test it out on quick look dev.
I'm new to Ornatrix and so far it's amazingly better and faster than c4d Hair. I took under an hour almost the same hair look and quality that standard Hair took me almost 5 days!!
I have this quick question that i cant seem to solve by my own. Looking at some help files, it seems i should be able to have multile UV tags when i add the Mesh From Strands and add more uv channels to it, but i dont have a single UV Tag showing up at all.
Basically:
1- easiest way to overall colour the hair using the underyling geo. Does it work not only textures and uvs, but also vertex colors?
2- additionally to that, if id like to use per strand uv, i guess then the multiple uv tags would be needed. Again, i cant seem to put them visible at all.
Thanks in advance!
Quick add:
1- i tried using the "export polygon" to make a collapsed copy, and the uv tags show up. It's, however, impossible to copy them to the Ornatrix object. They disappear instantly, only if i disable the mesh from strands op, but then it doesnt take into account the multiple uv tags.
2- however, there is some internal naming of the uv tags (ie -"channel2"), so even if the tags dont show up, i can still access them using their names, so it's a workaround.
I'm glad to hear that you like Ornatrix so far.
You don't need to convert the hairs to mesh to texture it. By default, the hairs will inherit the UVs of the distribution mesh/scalp/character. Paint the textures on the character and assign them to the hair shader.
This video shows how to color the hair along the strands.
Here you can see how to paint vertex colors on the strands. This is only supported by Arnold at the moment.
And some extra info about shading in the documentation.
All those examples are for Redshift, you may need to find equivalent nodes for other supported renderers.
It supports texturing using the underlying geometry and per-vertex colors in Arnold.
Per-Strand UVs just generates a separate UV island for each strand, not separate UV tags.
As you noticed, it has to be exported to get the actual mesh hair and the UVs. When Mesh from Strands is still on the hair object, the mesh there is not final, it is still a hair object, so you can to export it to get the final mesh. If I remember correctly , C4D doesn't support multiple outputs from a single modifier stack. That is why it works this way.
So, if you delete or disable Mesh from Strands after exporting the mesh, the UVs remain in the scene somewhere and you can still access them?
